Indicator switches?
  • thajack
    thajack
    I have fitted a new set of indicator switches to my 88 Softail. Unlike the original ones these only stay on while holding down the switch.
    Is there a way to make them work like the original switches?
    Cheers Jack
    Yep put them in the bin and put a new oem ones in I've been down that road too ended up changing the indercator
    Ones back to the oem ones if you look around eBay USA u can still get nos oem ones I know Harley Aus don't do them
    Any more I tried about a year ago And went eBay USA that do cost but worth it in my opinion it's sucks riding and holding the bloody switch on
    Will dig out the part numbers if you need them that's how I found them
  • thajack
    thajack
    Thanks for that mate,
    Looks like I will have to hunt for a set of OEM switches.
    Not to keen on having to hold down the switch all the time.
  • FXST11
    FXST11
    Why did you change them in the first place.?
    I found a complete set left & right with wiring up in Brisbane $450 plus about $13.00 postage.
    http://www.ebay.com.au/itm/321904769086?_trksid=p2055119.m1438.l2649&ssPageName=STRK%3AMEBIDX%3AIT
    might have to copy & paste
    http://www.ebay.com.au/myb/WatchList?MyEbay&gbh=1&CurrentPage=MyeBayWatching&ssPageName=STRK:ME:LNLK:MEWAX
  • thajack
    thajack
    I changed to chrome switches and housings as my original ones were worn and tired looking.
    Had a look at those ones you put up and they are later model switches.
    Thanks for looking though mate, appreciate it.
