Online: B0nes
Fat Bob Tyres
  • noonyjim
    noonyjim
    Has anyone found a better tyre for Fat Bob's than the Metzler ME 880's? I own a 2011 model.
  • FatRob
    FatRob
    I replaced my Dunlops with Avon Venoms.  I also went up a size in width too.
    No complaints so far.
    Regards,
    FatRob
  • noonyjim
    noonyjim
    thanks Rob...I've been running the Metzlers for a few years now, & was just wondering if there was something new or better out there.No complaints with the Metzlers......great tyres......just fishin' to see  if there's anything new.....
  • chriso
    chriso
    As posted the avons not bad..
    I run Pirelli night dragons only though these days, very grippy, love em.
  • FLIPDOG
    FLIPDOG
    yep, I too have always run night dragons, stick like shit to a blanket, only get 8000k's out of a rear though, but full confidence scraping the pegs at higher speeds
    I have on the rear of my softail at present a 200mm Michelin commander 2, also happy with the grip of this tyre at this point, all the reviews ive read claim twice the tyre life of other leading brands, done 4000ks so far with no significant sign of wear so this appears to be true, the N.D would be half worn at this point
    hope this helps
    cheers mate
  • shingles
    shingles
    yes am usin nite dragons great grip but will & will dissapear if agressive with launching at lights ,or just doin burnouts leaving from stationry posi but a verey good tyre at holding line in corners high lean angle run 40 psi rear 38 psi front
  • chriso
    chriso
    Yep you cannot run less then 40psi in rear or it will wear flat in the guts
  • FLIPDOG
    FLIPDOG
    38 front 42 rear for me
  • chriso
    chriso
  • BDA103
    BDA103
    Night Dragons on mine. Maybe not the best wearing but good grip when warm. 38psi front and rear.
  • chopa
    chopa
    bump your rear up 2 - 4 psi you will get better wear
  • fatboblkh
    fatboblkh
    michelin  commander !! 36 front an rear
  • lee
    lee
    Just got Pirelli night dragons. Don't delay. Just do it, the difference is massive from the stock rubbish. Instant confidence. No wondering on deviations in the road or squirrelly in tar snakes.
