Online: B0nes
Shorter brake and clutch
  • binnsy
    binnsy
    Hi all,
    I know this may have been asked and answered but I have searched the forum and cant find an answer.
    I have fitted a set of Burleigh t bars to my 07 fatboy and the original cables are way too long.  I have measured them (correctly I think) but where do I find some shorter cables?  Have checked HD out and cant find anything there and have had a look on some of the sponsors pages to no avail.
    Am I best to get these cable (brake and clutch) custom made somewhere or is there somebody some where who will understand what I want if I give them the measurements of the cables and the model etc. of my bike.
    Thanks in advance and i apologise if the answer is obviuous, its just not to a relative newby like myself.  There are pics of the bars on the bike in my pics if you need to see what Im on about.
    Cheers.
    i just have da stock one'sshorten to lenght, cheaper, i use Adanced insturment repairs in carrington st revesby very good @ it
  • binnsy
    binnsy
    Thanks daddyracer56 might see if theres something similar down here in Geelong.
    just post em up in a overnite bag with details, ive never had one broken  cheers
  • binnsy
    binnsy
    I still havent got these cables sorted yet. Got a guy in Geelong thats going to make a brake line for me but am I right in the fact that I read somewhere, the clutch cables on all big twins are the same length from the adjuster on the down tube to the transmission where they attach and I only need to measure from the clutch lever to the adjuster ie the top half, to determine what length I need?  Sorry for newby question.  I actually need to shorten the cable as i took stock fatboy bars off and put Burleigh t-bars with a six inch rise on.  Would rather replace the cable than shorten them as i want to put braided or similar on.  The ones on there now are plain black.  Thanks.
    braided are fuck but if you must, black is cool don't want a cable to stick out anyway  , no mechanial advantage in braided just  ( looks ), if you want it that bad buy a new barrnet type good brand cable not shit tiwain shit brand  , then meassure da outa lenght you want on da bike with a tape messure leave room for turning l to right etc  ,       have da inna to outa lenght made da same as stock that came off da bike , too easy sent them to Adavance Insturments in sydney for modify no worries been doing this for years
  • binnsy
    binnsy
    Ended up getting the brake line custom made. Took the bike to him today in Geelong and he made it while I waited. About 10 minutes and $85 Im a happy camper. Great service.
    Re routed the clutch so Im all good again.
    re-rooting is allways a good feeling
