Online: John.R
Exhaust Vibration?
  • Glaz
    Glaz
    Gday all,
    My 09 FXDF, swopped my SE slip on's over for my rush slip on's and got a lot of vibration ? never had this before.
    After test ride returned home and checked her out 2 header bolts were a bit loose.Tightened them up. Next Undid the bolts below and locked them all back up. A lot better but still noticable bit more vibration then the SE pipes I did play with the exhaust bracket near the gearbox. mmm.
    Anybody shed some light on this. Cheers
  • Glaz
    Glaz
    Thanks bro,
    One thing I forgot was to replace the exhaust clamps I'm doing that now. They are a use once item. See how we go.
