Online: John.R
advice needed - Bars
  • habba17
    habba17
    Guys,
    Recently posted this in the wrong area.... i think.
    I have recently bought a 13 street bob and am already spending good money on it. The PO had put the stock Softail slim bars on it, the ones that resemble a pushbike.
    What is everyone running on their bobs? What does everyone like.
    I like the feel of mini/mid apes 12" or 14".
    does anyone know who makes these or where i could order them?
  • Blackmagic
    Blackmagic
    I know where there are these Roland Sands for sale
    Moz
  • Methuselah
    Methuselah
    The black ones in your photo look like Burleigh Bars. You are on the Gold Coast so they can't be far from you, they're at 2/16 Ern Harley Drive Burleigh Heads.
  • shingles
    shingles
    u can buy part fits in bar recess bolts 2 tree then has been made 2 allow 1 1/4 inch bars 2 be bolted strate on so then u have lots of choices of the fat bar look instead of pushy bars ,mate did an put fatboy bars on controls an grips fit as bar thickness reduces at switchblocks and grips allows existing controls reused ,burly bars 2 hexy ive bought bars off ebay and also in for sale adds here used but 3 sets cost less than 1 set burly bars overated just my 2 cents
  • shingles
    shingles
    best an cheapest buy buy adapter that bolts into your fixed bar mounts then has new bolt on 1 1/4 inch bars all hd,s nearlly al av 1/14 inch an buy used bars an parts iav set fatbob bars and cables ans sum big beach bars but i wanted fatboy bars and bought here in for sale section costs nothin 2 place add ,but those addapter parts is wat ya need very well made and fat bars look da part cables all unplugg down near stearin lock just above rubber grmmet ya gotta pull dat out dish liquid helps if stuk that bung i could tell ya more but typed out ive done quite a few bar changes on hd certain things can be dramatic ,ill look those triple tree adapters cheapest way change bars on yor bike
  • Difficultmonkey
    Difficultmonkey
    Last weekend I put some Biltwell Keystone XLs on mine, happy with the look but I'm hunched over a bit too much so have ordered some risers. Will let you know what they feel like after that.
