Online: Fletch1953, Ultramick
lowering blocks on 2014 iron?
  • ben_faulkner
    ben_faulkner
    will blocks for 2013 and older sportsters work or do i need a specific 2014 and on version?
    anywhere i can get these in Australia?
  • brash
    brash
    Should all be the same, it just bolts to the shock mount (lower) and sits against the swingarm.
    Tamarak considered the best quality by most Sporty riders, you can get them through DK Customs in 1 or 1.5 inch.
  • 883n Harley Convert
    883n Harley Convert
    I've got a set you can have for $50 if you want them
  • ben_faulkner
    ben_faulkner
    thanks mate, sent you a pm.
