Online: GGUser761
Freedom Shields on Ultra
  • Nomada
    Nomada
    I just got an ultra and although I get a little buffering on top of my helmet, the missus reckons she gets quite a bit as she now sits a lot higher
    I'm looking at the freedom shields and guessing their 10 inch may eliminate my buffering but will it be high enough to eliminate hers or do I need a 11 or even a 12 inch screen.
    And advice from those who have gone down this road before my is appreciated.
  • mickle
    mickle
    I have the Freedom 10 and a 12inch shield, use the 12 inch in winter (that you don't have) 10 inch rest of time unless I put the Mustang
    seat on which is way lower then I put the stock Harley shield back on, 12 would be to tall for you as you don't have a Hammock seat which
    are very high, Jo doesn't whinge about much whilst sitting on the back or there wont be a next time. She has a wind block sitting in front
    of her so don't get much at all.
  • Nomada
    Nomada
    Ok.
    Julies is taller than me and sits higher than I do so she copes the wind that come of the top of my helmet.
    She didnt have that prob on the sporty.
  • Nomada
    Nomada
    Any more of any more?
    Maybe get a 12" clear Nomada . Oh , and change the script on the bottom of your posts .
  • Nomada
    Nomada
    I've been busy and haven't check the forum for awhile so it's never too late.
    Seems to be quite a bit of difference between a 10 and 12" screen.
    I've recently found out that my buffering is happening because the leading edge of my standard screen is vibrating at high speed.
    I get no buffering if I hold a finger up to it to and stop the vibrations.
    So I'm thinking of trying the free mom 10".
    Now if only their web site would recognize my post code.......
  • ftrk
    ftrk
    Hey Nomada,I had the same problem and fitted the 12" screen.  Still gets a little helmet buffering but definatly better for the passenger. The screen I used also has the slightly wider wings on it.
  • hosh
    hosh
    I have a new 9 inch medium tint for sale. It's for a Ultra. Only reason I'm selling is the top is right in my line of sight. I had to buy another one.
    PM me if your keen. I'm in Perth
    Update... 8 inch is now on my bike. Still have the new 9 inch for sale. $180
