Online: Retroman
Air shocks
  • animall
    animall
    hi guys , any one using or know someone with the knight industries air ride shock kit ? Good bad ? Any comments ? Thanks
  • Damo14
    Damo14
    Its basically the same as the kit I have on my Street Bob, I got mine from the Xotic customs in the states when the AUD was better saved over $150. Had it on my bike for nearly a year now works great, easy install and much better than stock.
  • Luisjovel
    Luisjovel
    Did you end up getting them installed? I'm interested in some air shocks for my iron also..
  • harley120048
    harley120048
    Hi Guys,
    Just thought i'd add this to the forum - I put air shocks of a Roadking on my 48 - I also needed to get 1" lowering blocks as the shocks them selves are 1" longer.
    They instantly changed the whole feel of the bike - less impact over bumps and so much tighter. I would reccomend this mod :)
  • Luisjovel
    Luisjovel
    Hey, what year roadking air shocks did you use? How much did you pay?
  • harley120048
    harley120048
    Mate Ill get a part number for you - They were second hand and all up I payed $400
  • Luisjovel
    Luisjovel
    Sounds good mate! Definitely keen.. Love the air shocks on sportsters!
  • harley120048
    harley120048
    Hi mate the part number for the shocks is 54661-02a showa - you can pick em up pretty cheap from eBay for about $90!!?!! The $400 I paid included the lowering blocks and a HD air pump, not sure if I was fucked in the ass there or not... either way the ride improvement was well worth the money to me!!
    I couldn't find a part number on the lowering blocks but I'll have another look later today and also take a few pics of the setup and post them so you can see how it goes ??
