Online: John.R
Brake light issues ??
  • Streetbob06
    Streetbob06
    Hi all,so I've noticed my brake light had stop working but my taillight was still good,I've gone and bought a new bulb today and replaced it but still no luck then I realised both lights in the bulb are on (new and old bulbs)which I believe means the brake light is in fact stuck on. Any one had this happen?? Any help would be greatly appreciated.thanks
  • AJ56
    AJ56
    Check your front brake lever is returning to off. And also your rear switch. If it is your front spray a bit of wd40 in and work the lever on the brake plunger...Failing that have you tekern off the levers ?  If you have you may have broke the nipple on the switch
  • 06 Softail
    06 Softail
    Thanks for the heads up AJ, I've had similar issues with my front brake switch sticking on sometimes. I thought of spraying a bit of WD40 to rectify the problem, but wasn't 100% sure if it was the right thing to do. Will give it a shot tomorrow.
  • gidgi
    gidgi
    check your wire loom under ya back guard it may have dropped down & rubbed onto the wheel
  • Far Canal
    Far Canal
    What AJ56 said + 1
    If it turns out to be the switch in the front brake lever assembly then......
    If you know a really good auto electrician its worth getting them to do it to save yourself the frustration as it's one hell of a fiddly  job.. Have heard of people fixing the swittch by gluing a bit of somthing on the end of it or putting a real small screw on the end of it.
  • chriso
    chriso
    There is a master cylinder service kit that fixes the issue. It is a common problem. Replacing the switch will often not fix the problem.
    I dont know exactly what's involved but I got my master cylinder serviced with the kit and was $80.
    Problem solved
  • taff60
    taff60
    Im with the chafed cable under the guard. Happens a lot particularly if your shockers are old and saggy or if you are on the heavier side. The cables short out.
  • taff60
    taff60
  • Streetbob06
    Streetbob06
    Thanks fellas for the advice,I'll try these things and see how I go.cheers
  • Streetbob06
    Streetbob06
    Ended up being the back brake switch under/in front of back wheel,35 bucks and it's all good again.
