Online: Soapbox2627
New speedometer
  • eliran
    eliran
    hi
    i have FAT BOY 2013
    i bought new speedometer (combination speedo/tach)
    the speedometer show me all the time 999999
    my bike has connetor with 6 pin but the adapter cable i got from H-D with the sppedometer has 4 pin.
    my Question is: how could i convert between them 4 pins to 6 pins.
    is it possible to convert between them?
    attach some pictures
    thanks for your help
  • FatRob
    FatRob
    I don't mean to be smart but did you read the instructions?
    It sounds as if you have not transferred the odo reading using the data plug under the seat.
    I haven't fitted one of these myself but it shouldn't need any adaptor cable, that is for the data transfer.
    Cheers,
    FatRob
  • eliran
    eliran
    the instruction was just to connect to new speedo adrive 30 miles and that it
    but the speedometer still show me 999999km
    as i understand i need to connect the speedometer directly to the ECM with the adapter cable
    but since my bike has connectoe with 6 pins and the adapter cable has 4 pins, i cant do it
    and here is my problem
    so i wonder if its possible to convert between them 4 pins to 6 pins.
    thx....
  • Drac
    Drac
    I think the later speedos just plug in and copy the info across automaticly and after 50 ks they lock to that bike.
    The earlier ones require the data cable to set them up before installing.
    I dont think they are interchangable between the two models.
    Not 100% sure though.
  • FLIPDOG
    FLIPDOG
    wrong part for your model
  • eliran
    eliran
    my model speedometer PN is 74777-11A
    according to H-D site its fit
  • xlr8it
    xlr8it
    Did You buy it new or second hand?
  • eliran
    eliran
    no, its was new
    i bought it almost 2 years ago
  • FLIPDOG
    FLIPDOG
    how'd ya go eliran, did ya have a win?
  • eliran
    eliran
    hi im ok
    what do you mean "have a win"?
  • eliran
    eliran
    not yet
    do you have any idea how to solve it?
  • FLIPDOG
    FLIPDOG
    no
  • imoo6170
    imoo6170
    Some notes from the Harley website and installation instructions:
    HARLEY WEBSITE (look in the Q&A tab) http://www.harley-davidson.com/store/combo-analog-speedometer-tachometer-pa-10-7477711--1
    According to the instruction sheet here:
    If you have a 11+ Softail, you just have to plug it in to your existing connector. It is not like the other speedometer where you have to use an adapter to hook up to the data link connector for the copy process.
    Thank you
    November 18, 2014
    INSTALLATION INSTRUCTIONS http://www.harley-davidson.com/en_us/media/downloads/service/isheets/-j05180.pdf
    This kit is a direct replacement for the original equipment (OE) speedometer on 2011 and later Softail models.
    Both the ECM and speedometer retain the odometer value. If the speedometer is replaced, it will display the odometer value stored in the ECM. The replacement speedometer will become locked to the ECM after 31.1 miles (50km) have been accumulated.
    So basically if you have done the 31.1 miles then it should be ok - you cannot use an adapter cable. If it is not ok, it is either broken or you have not installed it correctly. Either way take it back to the dealer and ask them
  • eliran
    eliran
    hi
    i already ride the bike
    i saw the plug under the seat
    when i move out the ECM fuse and return it back i can see the real Kilometers for 7 seconds and then the speedo show again 9999999
    and now i cant fix the real Kilometers
    i called H-D and asked them for the data cable with 6 pins that fit to my bike
    but i think they didnt understand and told me the cable cost 650$, is it real?????
    so what should i do now? how can i fix it???
  • eliran
    eliran
    hi
  • eliran
    eliran
    is it possible something wrong with my ECM?
  • Woodsie65
    Woodsie65
    This video will show you exactly how to do it
    https://www.youtube.com/watch?v=Vy0_-u146Ig
