Panhead case repair
  • carbon fibre
    carbon fibre
    G'day crew
    Anyone know of a tradesman/business here in Australia that can repair/restore cracked engine cases.
    I have a set of OEM 61FL cases with the RH rear engine mount area cracked, with a previously bad repair done..
    I have spoken to the Yanks and they definitely can be repaired and restored over there, but would rather keep the cases in OZ if possible.
  • carbon fibre
    carbon fibre
    G'day Bob, yep the belly numbers are matching. I saw that shop the other day. Lynden is a good bloke will call in and check.
    Thanks Dave, that is a great help.
  • carbon fibre
    carbon fibre
    Who By Chopa, they still around?
  • Dodgy
    Dodgy
    Stew Fyfe at American Restorations in Malaga would be able to point you in the right direction. 0401674428
  • carbon fibre
    carbon fibre
    Cheers Chopa
  • WAGlide
    WAGlide
    If you pm Daddyracer56 he should point you in the right directon
  • carbon fibre
    carbon fibre
    no wuckerz chopa, thanks for checking
    did you find someone to help out ,
  • carbon fibre
    carbon fibre
    nope, going to run the case with the battle scars as is
    Nothing wrong with battle scars gives it character
