Online: B0nes
fatbob fork seals
  • triumph68
    triumph68
    my sons fatbob did a front fork oil seal after only 20.000 klm the moco uses cheap shit the stealership wants $400 to replace them, F that . I have done fork seals myself a few times but i have 2 questions before i start the first one sounds dumb but how do you get the chrome cover with out damageing it is there a trick to it ?  and can some one recomend a better brand of seal that i can get in australia. thanks triumph68
  • Daggs
    Daggs
    The chrome covers knock off very easily, no damage to anything.
    There is a notch out of the slider where you can get a soft punch in there to knock it off
  • triumph68
    triumph68
    thanks guys Daggs im asuming you knock them straight up ? is there anything else that you think i should know thanks triumph68
  • Daggs
    Daggs
    its been a while since I had mine apart but yes straight up, do the side where the notch is a bit then work your way around, lightly taping until it is off.
    a manual would be handy of course, if you havent got one they can be found on the net to download...
  • triumph68
    triumph68
    hey loopie are you sure of that skf part number i cant find it anywhere thanks triumph68
  • fat55
    fat55
    Is there a problem with the factory seals ?
    Mine went with 12,000ks on it 2014 model and were replaced under warranty
  • Far Canal
    Far Canal
    Can't say about fatbobs but my fxst started blowin fork seals from day one...brand new. Got sick of changing them. Thought the fork tubes must be stuffed, bought new fork tubes and bingo! leaky fork seals. Had to put in the gas cartridge type front shocks and that fixed it cause they use hardly any oil.
    Maybe it comes down to the roads you ride on. I've got a veritable 6klm bitumen motocross track before I get to the highway and find my other bikes tend to get leaky fork seals as well.
    Not to mention the leaky crankcase centre seal , under warranty. Inner primary seal after that. Cylinder base gasket seal,etc etc.
  • FONTANA302
    FONTANA302
    Daggs is correct re the chrome fork covers, there is a notch on the inside of the fork leg that you use a soft drift to remove the cover from the fork leg (yes, they are Showa, so what ch out for metric bols on the fork if dismantling that for fork seal replacement/spring change etc.). The bigger issue is the re install of the chrome covers if it's tight on the fork leg (notch is of no use then) ......
  • triumph68
    triumph68
    Thanks guys $49 for the seals and I use automatic transmission fluid that I get from a mate that owns Ipswich automatics so it took an hour and a half and all done $50 repair yahoo you would have to fucken pretty stupid to pay $400 for fork seals !
    Great outcome Triumph .
