Online: Stuart
Dyno tuning graphs by engine mods
    This page is to store dyno tuning graphs and accompanying info in the one place so people can get an idea of which mods produce what results for a particular engine.
    This is my Roadglide with 103 engine, se ventilator, freedom 2-1 exhaust, se tuner and se 204 cams. The baseline graph isn't a true one as it has the above parts on the bike but with the se canned map in for stage 1 and without the cam change.
  • Hudson76
    Hudson76
    This dyno sheet is of my build in a carb'd 2001 Heritage Softail. Specs are as follows (to the best of my knowledge)
    95" kit with SE 9.3 pistons, Crane 302 cams, new cam bearings, new lifters and cam chain tensioner
    Heads ported and flowed, 5 angle valve job. Dyna-Tech ignition, SE air cleaner and V&H big radius 2+2
  • Daggs
    Daggs
    Here is my S&S 106
    S&S lifters
    60mm zippers throttle body
    4.9 injectors
    D&D Bobcat exhaust
    Ported & decked heads, 1.900-1.615" AV & V valves
    AV & V 0.640" springs, seals, man-decomps, 0.040" gaskets
    Crane HTC-296-2, 0.620" lift Cams
    S&S Roller Rockers - Forged
    AIM VPC and SE spring
    CR is set at 10.43:1
  • Independant_84
    Independant_84
    I have always seen such different results and heard stories about happy dyno's and humidity and pressure fudging etc. So i decided to look into it a bit more here are some interesting reads and what to look out for .
    http://www.badasscars.com/index.cfm/page/ptype=product/product_id=64/category_id=13/mode=prod/prd64.htm
    http://www.pencilgeek.org/2009/09/exposing-dyno-cheaters-how-the.html
  • Daggs
    Daggs
    Yeah she goes pretty hard Hilly, extremely happy with it. Lifts the front wheel very easily just powering on, no dropping the clutch :)
  • DarKasH69
    DarKasH69
    5 years ago
    My 2014 Fatbob. 117” MMVT Build
    True and welded crank with 0.0008” runout at the  cam plate... lots of goodies internally.
    Only done 20000km since this build but there is 115000km on the clock.
  • Grease Monkey
    Grease Monkey
    5 years ago
    Very decent Ash, who's heads and what cam?
    5 years ago
    The old FXR with a tweak
  • DarKasH69
    DarKasH69
    5 years ago
    Quoting Grease Monkey on 23 May 2020 12:38 PM
    MMVT Specials heads. SE 266 cams
    I’m looking for more hp/tq
    But it’s as strong as it was when built. Had a power run on a different Dyno than was tuned on, and it pushed same numbers.
    True testament to Ando at MMVT
    Might test with different exhausts down the track or take the comp from 11.1 up to 11.5 if possible. Give it another 10k km and see how it goes after that.
  • DarKasH69
    DarKasH69
    5 years ago
    Quoting tussuck on 23 May 2020 01:15 PM
    How’s it lasted with the turbo. FuKn quick peak in tq.  Monster
