Online: Fletch1953, Ultramick
New 48 won't start??
  • Night Rider
    Night Rider
    Hi all, first time caller long time listener etc...  Just bought a 2012 48 with 68kms on the clock.  Had on dramas at all with it until last night.  I went to start it up and had no ignition.  Lights, alarm etc were on but no crank at all.  Started perfectly the day before.
    Now, I have been leaving the key in the ignition but obviously not on.  Also, I just took the front pulley cover off.  Just wondering if somehow there's a safety switch on the pulley cover or have I flattened the battery by leaving the key in the ignition?  Any help would be appreciated.
  • brash
    brash
    check the battery terminals are connected, earth is maintained. Check main fuse is intact.
    Battery may have given up the ghost, my 2012 battery died earlier this year. Although I had dash lights.
    It's probably something simple. Hope you get it sorted
  • Night Rider
    Night Rider
    Cheers mate.  Figured it out.  Was something simple.  I rotated the switch blocks forward and I think I must've stuffed the connections.  Just loosened off the bolts and gave it a wobble and bingo.
    Thanks for the reply.
