ELECTRICAL
  • CHOOKA75
    CHOOKA75
    Hi All,
    Just new to the HD scene, I have a 2014 fat boy, V&H big 2inch pipes, Screaming eagle air intake all round nice bike.
    I washed it the other day, dried it, blew it down with air and everything you can do with a chamios.
    started the bike, put it in the shed, put the trickle charger on and covered it up.
    I went to start it last night, I have no dash lights, no indicators, no odometer, no crank, no hi/lo beam.
    When I turn ignition switch on, the Fuel pump pumps, But I dont get ignition.
    The alarm turns off, and on when turn ign switch off.
    Any ideas will be a great help....
    thanks
  • PeterGordon
    PeterGordon
    Mmmmmm, I'd be checking the fuses under the seat ;)
    Cheers,
    Pete
  • CHOOKA75
    CHOOKA75
    Hi Pete,
    Thanks, I tested them last night, they all tested ok.
  • mutley
    mutley
    this sounds like an earth problem if you have tested the fuses, how did you test them? test light each side while fitted or take out and visually see? because so many blown go past the seeing eye test
    good luck
    Sounds like a CAN bus fault
    Battery volts OK ?
    Still under warranty ?
  • AJ56
    AJ56
    Kill Switch
  • CHOOKA75
    CHOOKA75
    I have given up, She is at the doctors, they have to do computer tests. Looks like the old 2007 girl is coming out of the shed for the weekend. ahh well, lucky we have 2 bikes....
