Spinger front end for a fatboy
  • PigT
    PigT
    Hey all!!
    I have a 2001 fatboy and I was looking at putting a springer front end on it I was just wondering what size I would need to go to keep standard height, the ones I have looked at is 22" is that the correct standard height of the front end?
    Cheers PIGT
    Front Ends are mesured from the bottom of the Frame Neck to the Axle
    Sounds like you want to turn your fatboy into the old badboy model. Are you gonna go the skinny front wheel look or the fat front wheel like the cross bones?
  • PigT
    PigT
    Hey FATBAT, I'm going to keep the fat front wheel at this stage so it does have that old school look the only reason I wouldn't go a cross bones is with me and my partner we are around 200kgs (not small people) Hahahaha
    And thanks Walka makes more sense now
