Online: speedzter
Just ordered my Shotgun's for my FXSTSSE 2
  • ralphski
    ralphski
    Just ordered Shotgun's from JD & Jess from the States.
    early Xmas present.
    smileysmileysmiley
    Good choice Ralphski , the springer will look tough in the weeds , and rideable when raised .
  • Winger
    Winger
    Best thing you'll ever buy, Ralphski! Just about to do a write up on the fitting to my Heritage. Very simple, straight forward install with quality parts.
  • Squid83
    Squid83
    Yep I'll second that, they're upgrade.
    Great looking springer in your profile pic too, is this the springer it's going on? Defintely throw some pics up
  • ralphski
    ralphski
    yeh squid, going on my Springer.
    they arrived at Melbourne on Saturday.
    hopefully arrive Mon/Tues.
    Try and fit them for the National Meet Run, leaving Thurs.
    Winger, any problems that i need to know about? happy with them?
  • 06 Softail
    06 Softail
    What exhaust system have you decided to go with Ralph?
    Shotgun's are on my things to do wish list down the track.
  • Winger
    Winger
    Happy would be an understatement, Ralphski.They do everything you ask of them and then some, either solo or two up. Just spent the weekend around Victor down to Cape Jervis  and down to Normanville to see how they go with the missus on board. After a bit of experimenting with the rebound on some of the shittier parts of the road, i found a happy medium that made it a pleasure to ride. You can actually adjust the air as youre riding. As you might have seen, I'm a huge fan!. The only problem I encountered with fitting the Shotgun was my own dumb fault in not ensuring the wiring loom coming off the compressor had enough play to allow for suspension travel. Once I sorted that, it;s been faultless. And, hey Squid , weeds are okay ,but I like my lawn mown-HAhA!!
  • Squid83
    Squid83
    The hardest part is the air compressor can be a really tight fit on some models, apart from that it's a simple bolt in, plug in and play setup
  • GT 1200
    GT 1200
    That's a nice rig Winger yes
  • ralphski
    ralphski
    fck, i was hoping to get the shocks today.
    they arrived in Melbourne on Sat.
    SHOULD turn up tomorrow, but that only leaves me one day to fit and sort them out for the National Run on Thurs.
    Don't want to fit them and have problems/issues on the way to Echuca etc.
    +1, nice ride winger.
    catch you boys for a ride and beers some time.
  • DR
    DR
    + 1 for shotgun shocks, the best thing I have added to my bike
  • ralphski
    ralphski
    finally fitted them today.
    little bit of fckn around, but all ok.
    hopefully the rain will fck off Sat, and i'll go for a quick ride to sort them out.
    Take some Pics please ralphski.
