Online: Hilly, speedzter, Wanderer57
Cast Alumium Timer Cover grinding ??
  • BBYHD
    BBYHD
    Hey all,
    Any ideas on what is best to use to grind out a small section on the rear of a cast aluminium timer cover to make it fit XL883 2008?
    I only need to grind in a 20mm diameter hole 1-1.5mm deep.
    I tried using a standard Dremel grinding bit but a) will take a while, and b) started to deform the tip.
    I know they have Tungsten Carbide dremel bits that would probably cut cast aluminium well enough but they are $$$ for if it doesnt!!
    Or does anyone local (Ferntree Gully) have a tool that could do it easier?
    Thanks!
    Chris
