Online: Retroman
wheel bearings
  • Fat Tom
    Fat Tom
    I wish to powder coat my 07 fatboy rims Satin Black so they look like the fatboy Lo rims .
    Powder coater says 200 degrees celsius for 10 minutes. Will I need to remove the wheel bearings for this?
    If not , are ther any precautions to take
    If yes , could I leave them in there and pull them out after and renew in 1 go or do they have to come out before
    Thanks in advance
    Pull them out and put new ones in when you get the rims back match them up at any good bearing shop around the $12 buck mark each for good Nsk bearings not the shit Harley use you may have to use a razor blade to scrap some of the
    Powder coat off if they don't tape up where the bearing sits in the hub no real big deal though
  • Fat Tom
    Fat Tom
    cheers for that. Will check out the bearings too
  • brush
    brush
    had some rims powder coated a few years ago, removed the bearings, got some threaded rod and washers same size as the hole, stops anything from gettin in. cheers BRUSH.
