fatboy lo rims
  • Fat Tom
    Fat Tom
    Can someone tell me if I can put 2010 fatboy lo rims on my 07 fatboy. Really like the black detail and need info to decide whether to buy rims and put on
    or take my standard rims off and paint.
    Ta
  • Hudson76
    Hudson76
    I think you're outa luck there buddy. If I'm not mistaken the '07 Fatboys had an offset front wheel on them and i think the axles are still 3/4 inch diameter, where as the 2010 ones will be the 25mm axles. Probably getting your's done to that look would be the easiest way around it. Please some one chime in and correct me if I'm even slightly off.
