Online: Soapbox2627
Foot peg relocator, which one??
  • binnsy
    binnsy
    Fitted V&H 2 into 1 to my 07 fatboy and obvioulsy had to relocate the right side pillion foot peg to clear the exhaust.  Now I need to get one for the left side so the other half isnt sitting at 45 degrees.  I see there are two, one is the same as the right side (pic2) but the other is a bit weird looking (pic 1).  Anyone else fitted one? and if so which one did you use.  Also where did you buy it? seem to be a bit rare in Aus.  Thanks.
