Online: Wanderer57
change my V&H big shots for 2 into 1 thunderheaders?
  • ralphski
    ralphski
    currently have V&H Big Shots on my SE 2008 Springer.
    looking at changing to Thunderheader's, good/bad idea?????
    after a little more hp and tq.
    should also be not as loud.
    quality of the thunderheaders ????
    performance ???? etc.
    thanks boys
  • EBT
    EBT
    Hi Ralphski,
    I have done some testing with both those pipes over the years. Both pipes have similar power charastics. They have a low Torque entry to the rev range and sometimes they will have a dip at 2,700 rpm before it starts to work again. Both a bit soft till you get to about 3,000 rpm then they start making power from there. The Thunder Header seems to make a little bit more peak horse power. As far as noise goes it's not called a Thunder Header for nothing. When you open the throttle it gets loud. Both pipes have very specefic tunes to get the best out of them. You will need a tune before you can try to feel any real changes.
    Cheers,
    Brian.
  • ralphski
    ralphski
    Thanks Brian,
    seems the Thunderheaders lack quality also.
    i had a chance to change my pipes for them.
    At this point in time, have declined.
    looking at my dyno figures, no real drop off.
  • ralphski
    ralphski
    Thanks Brian,
    CVO_'08_Springer_DYNO.pdf
  • 06 Softail
    06 Softail
    Any updates on choice of pipes yet, and have you had them fitted?  Looking forward to seeing your ride in the flesh soon.
    Cheers.
  • ralphski
    ralphski
    really happy with the performance, ( will be better when i swap my pipes for 06 Softail's pipes ), he just doesn't know it yet.....
    standard 110B, unsure of the cams, but not the 255's.
    if i can swap my pipes for V&H 2-1's, i'll pull the cam cover to check.
  • 06 Softail
    06 Softail
    Haha Ralph, so you like mine do you? I do too. They look & sound great on a Softail, especially after a decent tune up.  Supposedly they are good for torque too so I hear.
    They'd look pretty sweet on your ride too, but I'm not going to part with them any time soon, sorry mate.
    P.s, let me know when you want to swap that back wheel of yours, cheers.
