Online: Soapbox2627
Tombstone tail light
  • Winger
    Winger
    Have any of you guys changed a standard Heritage tail lamp/ upper number plate assy to the Deluxe style tombstone type with an under mounted number plate bracket ( the clear number plate illumination panel would (obviously) have to be underneath and not on top. (see attached pic) Already got the smaller indicator bar, but the original lamp set up is quite ugly with the number plate sittin' up like Jacky above it. Any help appreciated. Cheers, Winger.
  • rodrocket
    rodrocket
    have a look at this, it may be what you are looking for
    http://softbrake-com.3dcartstores.com/SoftBrakes-Tombstone-Taillight-Housing_p_50.html
    also this
    http://softbrake-com.3dcartstores.com/SoftBrakes-Stainless-Steel-License-Plate-Relocator_p_45.html
    I have both here, bought it for my Deluxe never used it, if its of any use to you make me an offer
    regards
    Rod
  • Winger
    Winger
    Looks exactly what i was checking out on the yank bikes, Rodrocket. I assume the number plate relocater clips under the base of the housing. Lense and guts  separate again ? (Same as HD Deluxe part?) The other thing was, how does licence plate illumination go with the relocated plate holder? Give me a price including postage and I'd be very interested. The one main thing that I'm concerned with though ,would be that the tombstone light covered the hole over the Heritage original lamp cut out. Any idea if it is wide enough to cater for this ?Cheers, Mate.
  • rodrocket
    rodrocket
    I believe it covers the complete hole
    let me see what other info I can find on it, otherwise maybe email softbrake & ask them
    regards
    Rod
  • Winger
    Winger
    I'll turn on Mr. Google and see what he comes up with and check up  with Softbrake. Appreciate your input , Rod.
