Online: Fletch1953, Ultramick
Pipes for a 97 883
  • Sporty97
    Sporty97
    Hey guys,
    I'm pretty green when it comes to Harley's but with my research it seems as though bolt on pipes for a 97 aren't as common as I would've thought.
    I really like the look of the V&H short shots, does anyone know of anything similar you can get that will bolt on to a 97?
    Alternatively, any idea what a custom set of pipes that look the same/similar would cost to be made buy an exhaust shop?
    Thanks in advance,
    Tim
    The problem with your year is the Rear Master Cyl , 2004 and up have it mounted on the swing arm not on the Sprocket cover, I have seen so guys make a new mounting bracket for the pipes but they almost rub on the master cyl . I can get you some Chrome Staggered Short Shots to fit 1999 to 2003, they should fit 1997 $680.00 Ian VPW 03 8405 9212
  • Sporty97
    Sporty97
    Thanks Ian, can you get them in black? And also how much would it be to get them to Sydney? Thanks
  • Sporty97
    Sporty97
    thanks i'll keep it in mind
