TTS Start Calibration
  • rusty0031
    rusty0031
    Hello
    I have an 06 Dyna that has 95 CI 10.25:1, SE211 cams and a V&H 2 into 1 and I am looking for a map to start to Vtune with but can't seem to find anything ?
    Thanks
    Welcome back Hilly. Good to see/hear you.
    Rusty, Hilly knows a fair bit about TTS and is a long time poster here (just left and rejoined which explains his post count).
  • Robbdasnake
    Robbdasnake
    Gday Hilly. Hope ya good mate.
  • rusty0031
    rusty0031
    Isn't DNO176 to much for what I have in it, will it run to lean?
  • rusty0031
    rusty0031
    Thanks for the info ,I do understand it and will set it up with the DNO map and give it a try.
  • Jayman6
    Jayman6
    Good to have you back Hilly
  • rusty0031
    rusty0031
    Hilly yes I did make 3 good runs with the DNO cal and Vtune made big changes to it i think it was to much for i have so i went with the CAA it seems to run better from the start, only made one run with it so far. I'm not shure if the DNO had that issue or not.
