Wiring on 96 heritage same as 07 fatboy?
  • binnsy
    binnsy
    Hi all,
    Im looking at a set of bars on e-bay at the moment that came off a 1996 heritage. They have the wires all still inside the bars and controls etc.  Thought it would make it a lot easier to fit them to my bike as they are all in one piece.  Question is, my bike is an 07 fatboy.  Will the wiring match up can anyone tell me? The wiring on the bars still have the connectors attached.
    Heres what they look like, hopefully the guy selling them wont mind me posting a pic.
    Dunno about wiring but I know heritage and older bikes use 1 inch bars standard and your 07 fat boy uses 1.25 inch bars standard
  • binnsy
    binnsy
    Thanks fatbat, pardon my newby ignorance, but by that do you mean where the grips are on the bars is 1.25 on the fatty and 1 on the Heritage?? The bars in the picture are Chubby brand apparently. Sorry shouldve explained.
    When I say 1 or 1.25 inches, that's the thickness of the handlebar although the 1.25 inch bars taper down at the grip. Those tbars will replace your risers so you need to make sure that where they bolt on that they will fit. Ask the seller or manufacturer I reckon. Good luck
    All bars are 1" at the Grip,,, No the Wiring is different 1996 to 2006 are the same, 2007 and up have a Clutch Switch on the clutch leaver
  • binnsy
    binnsy
    Thanks walka, sorted that out for me...
