Squeak in throttle
  • careyman
    careyman
    Hey, what would you guys use to lube your throttle cable?, when i roll off the throttle i get a little chirp...(2008XL883c). Someone at work said there is a silicon based lube but wasnt sure of the name???
    What you just said silicon spray lube pull apart clean and lube
