cant find footpegs to fit 2011 sporty48!!
  • Tim48
    Tim48
    having trouble finding pegs to replace standards on my 48.After purchasing new willie g pegs i was annoyed to discover  the bracket that holds the peg is longer at the top than the bottom making fitting aftermarket pegs impossible. I've since tried to find others to fit with no luck. I'm considering having the bracket cut back but seems drastic. anyone had same problem how'd u solve it?????
  • FLIPDOG
    FLIPDOG
    that's a bit of a cunt there timmy, you sure the receiving mount in photo is original ? It looks as if it can be removed
    im not savvy on sporties but on some bikes (not necessarily HD.s) you can change this docking hardware to suit aftermarket pegs (kuryakyn ect) and most likely HD oem
  • Tim48
    Tim48
    Tah for the reply.Yep all stock. managed to remove docking brackety thing & found a engineering shop that can shorten it so that should do the trick otherwise yeah aftermarket hunt is on. mates softail breakout has same set-up so looks like there'll be a few people running into same problem.
  • GT 1200
    GT 1200
    You need to buy different "clevis"? (mount) to suit. Mine was a bit of a pain as I did not have cir-clip pliers to suit, then wrong size allen key!
    or plan B, angle grinder!!!
    Edit: Plan C is return the other pegs and buy pegs to suit your bike, but these are mostly the skinny ones.
  • Tim48
    Tim48
    grinder it is!!!! love these pegs & have matching shifter derby, axel covers etc already fitted so thinking go the chop & paint em black.....
