Online: Soapbox2627
Final drive chain conversion
  • mark2_2
    mark2_2
    heys guys
    i need some advice im currently building a 2010 FXDWG dirt dragger i need to convert it to a chain drive i need to know who can supply this kit and ease of completing it would like to use a 630 chain as i will be upgrading in the future to accommodate the hp
  • Nirvana ride
    Nirvana ride
    Not sure if this is what you're after but saw it as was searching for bits n pieces this evening.
    http://www.ebay.com.au/itm/Belt-To-Chain-Conversion-Kit-For-86-Up-Softail-Harley-Custom-Motorcycle-/320858311219?hash=item4ab4a54a33
    Might be a starting point to finding the right fit/part.
    Good luck with yer project!!
  • TJU
    TJU
    There is a mob called 3 Guyz that might be worth a look .
    L A cycles in Sydney converted my 01 Dyna TC 95" to chain, not one problem has covered 100,000k in past 14 years with that chain still has original chain n sprockets  still going strong, I road to NQ from Sydney n road up Willowbank to race n ride home few times that's up there race next two days n ride back to Sydney next day, was runing 11.2  with best speed 121mph in 4th gear that's just a 95 with a deaf disabled useless rider ha ha stock shift 130 16" Avon rear tyre stock clutch se diaphragm no tricks just set up n tunes by L A cycles Sydney
