Online: baldy1450
No oil pressure after evo rebuild
  • Harley97
    Harley97
    no oil pressure after rebuilding my 1997 evo motor do have oil where tapper oil filter is but when turning over lots of air bubble coming out and where my ball bearing and spring is on top of oil pump when removed oil is coming out but has air bubbles to do I keep turning motor over until all air bubbles stop some would be nice thanks
  • DocGreen
    DocGreen
    Hey Harley97, a little more info on what you actually did during the rebuild mate may help guys help you. Are you only cranking the motor and not actually starting, and have you actually checked oil pressure - not just used the idiot light? Changed oil lines and hooked up wrong? Give as much detail as possible mate.
    DocGreen
  • Hound_Dog
    Hound_Dog
    Post an intro and the boys may be more inclined to help you.
    start from feed line 1st & then down from there, leave check ball out , & push in top gear without  any spark plugs in   & then see , whta cuming out could just be & air lock , what grade of oil ?
