S&S 58mm throttle body stock air cleaner fitment
  • mark2_2
    mark2_2
    hi has any one installed a s&s 58mm throttle body and used se stage 1 air filter will they fit or is it better off putting s&s air cleaner thanks
  • EBT
    EBT
    Hi Mark,
    The SE stage 1 Hi flow kit wont fit. The last time I fitted that throttle body we used an S&S tear drop style Hi flow kit. We needed to modify it a bit to make a perfect fit. It had a 2mm lip that needed to be removed . Apart from that it worked really well. The injectors were a bit of a problem though. The ones they supply were either too small or too big. I found some Chevy Camero injectors that were perfect.
    Cheers,
    Brian.
