Online: baldy1450
Lost Keys options???
  • Davidnorena1
    Davidnorena1
    Hi guys
    So ive lost both sets of keys to my softail deluxe 2011 model, yes i know im a goose.
    Ignition is unlocked so i can still ride it as its an import and has no immobiliser but what are my options as to geting replacement keys?
  • AlHD48
    AlHD48
    go to a HD dealer they can help
  • Geoff3DMN
    Geoff3DMN
    If you have the key code then some locksmiths can look it up and cut a new barrel key (not all of them).
    Failing that some will be able to cut a key from the original lock but that will require getting the bike to the lock smith or the lock smith to the bike (and may mean removing the lock from the tank).
