Online: wildchild, Ratbob
  • DUGE
    DUGE
    HI
       HAS ANY ONE TRYED WF1 CLEAN AND WAX?  A BLOKE WAS ROUND THE OTHER DAY FLOGGING IT DOOR TO DOOR, I'VE ALLREADY GOT MORE POLISH, WAX, ETC THAN I CAN USE. SO I DIDN'T NEED ANY THING. BUT I LET HIM DO HIS SPEEL.   IT WAS A BIT LIKE MR SHEEN, OR MEGUIAR QUIK DETAILER, BUT IT TAKES OF BUGS AND SUCH. WAS A BIT DEAR. HE RECONS IT WAS DEVELOPED FOR NASCAR IN THE US.   ANY WHO,,,,,,,
    DOUG
  • Spook
    Spook
    Plexus is what I use.....bloody magic stuff!
  • Sparra
    Sparra
    NO
  • FLIPDOG
    FLIPDOG
    WF1 WTF
  • Soapbox2627
    Soapbox2627
    I have had a couple cans of it over a few years, I found as I was using it, i did not have to clean the bike as much with soap and water. you can spray it on, even it out, then with a clean cloth polish it off.
    once you cloth is "wet', it does go a long way, I have the same aplicator cloth (micro fiber) for a few years so it is "conditioned"
    I get a fair bit of dust yet it wipes off easy, paint and chrome shines.
    I do avoid the engine but the primary case and gear box clean up well also, it is a piece of piss to use
    I used to wash then turtle way, this does halve the time
    I will continue to use it
  • DUGE
    DUGE
    Hi Soapy
    Thanks, I'd never heard of it and I'm always weary of sales-people. It was the price of it that put me off, he wanted close to forty bucks for a 475ml can....and I always hear that voice in my head saying, if it sounds too good to be true it generally is.........lol
  • steelo
    steelo
    I purchased FW1 from some lads pushing it at the local servo. Really liked it. I found that I always washed the bike first with water (I know, your sposed to be able to use it on a dirty bike) and then the spray on the tins, screen and wheels. Really bought them up a treat and had a lasting effect making dirt easier to remove.
    I found that after a while though, a can lost pressure and I wasted a couple cans. The next time I was at the servo, I told the new guys selling the stuff and they replaced it no probs. Try and get the pistol grip attachment. Makes spraying easier as it comes out foamy.
    I then had a chance to try aussie made "nowet" which was promoted through work. This is fantastic, comes with a simple spray bottle where the lids pumps the pressure and removes all sort of rubbish, dirt and bugs. I bought a 4 litre container with a mate. Lasts forever, and I think I like it better. Thats the one I take away with me.
    Can be purchased in every state and if you need, I can give you the details of a south oz dealer.
    http://www.nowetcarclean.com.au/
    In the end, whatever you get, it will protect your investment but I just cant get my head around using it without washing dirt engine and wheels first.
