Online: baldy1450
Daymakers on fatbob
  • Richo89
    Richo89
    Has anyone got the daymakers on the fatbob and wonder by the look of them there's two lights in each side,are both sides on at low and are both at high position
  • Bozza
    Bozza
    This is all i could find for Fat Bob daymakers
  • chriso
    chriso
    It will be wiring mate as the shells for domestic and international are the same but wiring plugs are diffrent.
    Get the domestic headlight and a H13 wiring harness and you will be right, its expansive (around $300) but you will kill two birds with
    the one stone also benifiting by having both daymaker lights on at once insted of the one eyed jap look.
    If you need to know more use the search bar, plenty of us have done it
  • chriso
    chriso
    Can't understand what your saying but no they not the same. Domestic and international plugs are completely different and it seems the only one that takes daymaker is the domestic one, UNLESS the wiring conversion has already been done beforehand  to accept the domestic one. Hence my post above.
  • pat
    pat
    ?my usa lamps plugged straight in
    says "not compliant" on hd site
    bit bloody dear
    heaps on alibaba pages
    http://www.alibaba.com/trade/search?fsb=y&IndexArea=product_en&CatId=&SearchText=daymaker+harley
  • chriso
    chriso
    So your domestic (USA) headlight plugged straight into your Australian bought fatbob. Is that what your saying??
  • chriso
    chriso
    Well thats a first for me, cause the plug on the back of my domestic and the plugs on the bike were different. had to change the plugs on the bike to fit headlight ?????
    I know most were like that cause there was a lot of talk on the forums about the hassle of the changeover to be able to get both lights on.
    If thats now the case everyone should do the simple changeover.
  • pat
    pat
    Yep straight in
    Cost $300 and near got that for old one
    http://pages.ebay.com/link/?nav=item.view&alt=web&id=151781104109&globalID=EBAY-US
  • chriso
    chriso
    Your bike definately not an import??
  • FatRob
    FatRob
    On mine, a 2010 assembled, 2011 MY FatBob the domestic light unit was a straight swap for the international one.  No mucking around with the wiring harness was needed.
    The only difference really is that there is one less wire coming out of the headlamp assembly as the domestic doesn't have the pilot light.  But the plug was exactly the same.
    Cheers,
    FatRob.
  • Towball
    Towball
    Hey Richo,
    I know its almost a year later, but I just found these on a QLD based business.
    https://hoglights.com.au/products/fat-bob-led-headlights?variant=13145434372
    Gonna get them for my 2015 FB in a month or so
