Online: Humbug, brucefxdl, Merv
4` advance key for gear drive, where to buy??
  • spunky_man
    spunky_man
    having problems finding the 4` advance key for gear drive cams. where can I buy this key???
    thanks in advance
    Baz
    Contact andrews in the USA or Rollie's in qld.
  • FONTANA302
    FONTANA302
    Got mine from Rollies
  • spunky_man
    spunky_man
    thanks guys, but Rollies I thought only does distribution now don't they. no shop front I thought any more???
    will only work on chain drive cams ?
  • spunky_man
    spunky_man
    rang them today, could not find a part number in there catologues, so no go unless I can find a part number!!!
    Fontana, can you remember a part number and brand??
    thank
    baz
  • spunky_man
    spunky_man
    no this will not work with chain drive cams because of the spline on drive sprocket!!!
  • FONTANA302
    FONTANA302
    Andrews Sprocket (+/-4 degree) #216323
  • spunky_man
    spunky_man
    thanks Fontana but not what I'm after. what I need is the key used for the standard gear that can be used to +/- 4` depending on whitch way you turn the key. but how much was the gear can you remember
