Online: speedzter
ten mm leads
  • Hoodaman
    Hoodaman
    I just put some SE 10mm leads on the king and it seems to generally run faster ..... Is this just my imagination or do they really make a diff??? I didnt expect anything other than lookin nice.....Fill me in.....its just my imagination aint it???/
    Thanx guys.
  • Phillthy
    Phillthy
    As long as you think they make the bike go better, it is all good.
    Your other ones must have been shot to make a huge difference.
    Generally they don't make a big difference. Maybe you should get some of those frozen plugs too.
    I went to Auto Barn and got a set of blue 8mm ones for my bike. Cost me $10 and they look good.
  • Hoodaman
    Hoodaman
    Thanx mate...i didnt think they should make a feelable diff...the ol ones looked like shit so i think ur right......oh welll they look really good
  • SuperGlide
    SuperGlide
    I just got mine in from the USA tonight Hooda'
    Have'nt fitted yet but my 10mm S.E. leads are RED ones though so I KNOW THEY'LL BE QUICKER.
  • Hoodaman
    Hoodaman
    heya Alby.....seems to have noticeably picked up performance mate.....i figure the last leads were not the best.....and damn they look good too.
  • SuperGlide
    SuperGlide
    Yes am loving my red S.E leads, had em' on for a little while now, all good.
  • jordan
    jordan
    the se 10mm or 8 mm have the same resistance as the stock leads but they have thicker insulating to avoid shorting in high voltage coil applications, they only help as much as stock leads when replacing old leads.
  • andij
    andij
    hoody maybe your admirin ur new plug leads and ur seein the road goin past and ur thinkin iam fucken flyin .
