Online: Lushy
vance and hines grenades on breakout
  • Theironbear
    Theironbear
    hey guys,
    Anyone know if they will fit the breakout? says they fit all softail models on the vance and hines site but when you go to select bike options on any dealer sites it never has breakouts listed. I know a lot of people say most softail pipes will fit a breakout but im just curious and want to know before I order them.
    Thanks in advance
    I've searched heaps but cant find any answer
  • Retroman
    Fucking BOLLOCKS they will !
    Slip on mufflers may be the same and /or interchangeable , but the headers/downpipes are WAY different
    That's down to the stepout due to the 240 rear end
  • Theironbear
    Theironbear
    Thats what I thought. maybe due to the grenades being shorter they will fit?
  • fmx austin
    fmx austin
    I have fitted 2-1 big radius for regular softail to my cvo breakout without any clearance issues at all. I won't say all pipes will fit but the v&h 2-1 def do. I took a gamble buying them but am glad that I did.
  • Theironbear
    Theironbear
    Awesome! thanks for the info mate. I really wanna go something different and put the grenades on.
