Bike is not starting after 14 weeks
  • Retroman
    Is there a spark ? Do the spark plugs smell of fuel ?
    Is the battery in the keyfob good ? ( I have seen this many times being the problem !)
  • FLIPDOG
    FLIPDOG
    didn't you put one of those used but re-freshed/re-programmed Screamin Eagle tuners in the bike?
    if so, maybe it could be that
  • FLIPDOG
    FLIPDOG
    yes it is and yes it will be,
    oops!
  • FLIPDOG
    FLIPDOG
    I wasn't out to try and achieve anything and it wasn't a stupid "comment"
    it was a legitimate fucken question ya dumb cunt
    and for your knowledge, I really couldn't give a fuck about ya tuner, or why your bike wont start
    Ease up flip dog or the ranger will be around to put you in the pound lol
    As for your fuel hose being 10mm not 8mm that would do nothing an less your clamps are not tight
    And the fuel squirting out the side of the fitting you only have a small amount of hose not
    Several mtrs of it to lose that much pressure and flow and if its hooked up right she should run
    Disconnect the fuel hose and see if fuel flows out of it when the Ign is turned on.
  • Sparra
    Sparra
    Good work...yesyes
