Online: obisteve, John.R
RB Racing Exhaust Gasket
  • Chris DILLIGAF
    Chris DILLIGAF
    G'day, just wondering if anyone has ever ordered from RB racing? I bought my bike with the pipes already fitted and am going to change them to the stock ones shortly to pass rego inspection needed to change from NSW to NT. I went onto RB racing website to order a kit with exhaust gaskets, flanges, clips and nuts. It looks pretty straight foreward until I get to the payment section asking me to message through my credit card details and the 3 digit number (CCV) on the back. Im not sure if this is a good idea or not? Has anyone bought anything from these guys?
  • FLIPDOG
    FLIPDOG
    hey chris, cant you do a direct deposit into THEIR account?
    I would email/contact them and request their account details for payement
    tell em you don't have a credit card mate
  • Chris DILLIGAF
    Chris DILLIGAF
    Hey cheers mate. I checked them out and they don't take direct deposit to their account. It seems the only way they do, is if you are buying a turbo kit 7-9 grand and if you do it incurrs a 50 buck fee on top. Never come across this before. I may have to grin and bare the yanky accent and give them a call. I'm sure I'm on the right website but it just doesn't sit right.
  • FLIPDOG
    FLIPDOG
    is there something special/different about their gaskets, flanges clips and nuts?
    the exhaust ports on the engine are all the same on your model so therefore the fittings I assume would also be the same no matter what manufacturer.
    you buy the gaskets that suit the engine not the pipes wouldn't you?
    I would try and source an alternative
  • Chris DILLIGAF
    Chris DILLIGAF
    This is what the gasket looks like. Seems to be totally different to the standard one. If you scroll down on the link there is a picture of it on the pipe. https://www.rbracing-rsr.com/downloads/LSR21Sportster.pdf
  • Evo
    Evo
    Chris, they have been around for some time. Just make sure they have the parts in stock. I looked at getting an exhaust for my shovel FXR and it was going to take 3 months........ Ended up having a local exhaust mob build a custom pipe for me. Check around for an aussie supplier if you can. Cheers
  • Chris DILLIGAF
    Chris DILLIGAF
    Cheers for the reply mate. I will definitely check around Australia first. 3 fkn months??? WTF??? That's a damn long wait.
  • Ando
    Ando
    Just get some Screamin eagle exhaust gaskets and genuine exhaust nuts. or get onto rollies and get some cometic steel exhaust gaskets
    can't see any reason to get the R&B stuff
    The Rb gaskets are re usable, or as Ando says
    Just use any flat style gasket.
  • Chris DILLIGAF
    Chris DILLIGAF
    Thanks for the replies everyone. I installed the screamin eagle exhaust gaskets. All good now.
    hope all sorted, just thought i't say SE exh gaskets always work well, same exhast port, pipes are pipes, be they bagpipes or trumpet
