Tyre experts fitters info needed
  • Independant_84
    Independant_84
    Has anyone ever fitted or know if a 200 tyre can be used on a breakout rear rim.
    Or what other options will get it as narrow as possible.
    And any maximum widtth measurements with tyres fitted the rims are 225 mm at the widest points curious to see what they are with a tyre fitted as well.
    There is no option to go narrow, The Rear Wheel is a 8" 200 Tyre fit on to 5.5 to 6.25 Wide Rims
