2013 fatboy whats the best cams/ sizes to use
  • bignuts
    bignuts
    Hi all wanting advice on what cam kits to use for 2013 flstf fatboy and a fxdb streetbob allso a 13 model lady rider?
    would like a lumpy note and performance and torque all way through.
    also what else do i need to purchace for doing this?
    TIA for any info.
    wayne
  • locks
    locks
    With no other work done apart from mufflers and air for the lumpy note and linial gains you could do worse than SE 204's in both.
    That said there are many cams out there that are bolt in, you would be happy with 204's though.
  • Arron
    Arron
    I am happy with the Andrews 57H cams i put in the 2013 street bob (it's a 103) , more of a low to mid range cam . The fuel usage seems to be near on stock.
    I did the lifters in mine , two of the four lifters had little to none of the hard-facing left on the rollers so i would recomend changing them while you are at it.
    My bike only had 13,500km on it when the cams were changed.
