Online: beaglebasher, Nino
Help with led blinkers
  • catman
    catman
    i have put led blinker all round and narva load resistors on and my blinkers start to flash ok ,
    but after 4 blinks they speed  up and the red key light  stars to flashes on the speedo.
    does anybody know the correct procedure to re calibrate the blinker module.
    i have tried the key on 4 blinks left then right and key off but still no good.
    i have a 13 nrs.
    any help would be great thanks
    Greg.
  • PT
    PT
    G'day Catman , had a similar problem. Could be the way you have the resistors. Ya know wired in Series or Parallel. I had individual resistors but then decided to change them due to the amount of heat generated when the indicators (turn signals) where in use for extended periods
    (stuck at traffic lights & railway crossings etc) Those things get dam hot. Went for a Badlands module through Easy R Australia (1 of the sponsors) Great blokes. Anyway sounds like ya resistors might be wired in incorrectly.
    I will check this posting from time to time in case I can help
  • catman
    catman
    Thanks pt.
    You may be onto something.
    I have the resistors wired in series to the front blinker supply only for each side , need to check a wiring diagram.
    How much was the module you fitted
    Regards Greg
  • ralphski
    ralphski
    Go to page 2, near the bottom.
    there'll be a post Biketronics BT801V load equalizer.
    might help
