Online: fxr89
Re tune ?
  • AlHD48
    AlHD48
    Hi All
    I have a HD sporster with a screamin eagle heavy breather , with stage 1 download and vance and hines short shots , its already been tuned.
    If I put on quiet baffles , do I need to re tune ?
  • locks
    locks
    Gday, by tuned I'm guessing your talking about the stage 1 download?
    If that's the case its not really tuned but rather pushed in a more desirable direction tune wise.
    If you look up the SE calibration they flashed into your bike you will see that does not mention V&H pipes, every detail you change from what is written in the calibration description is a difference from what that calibration was developed with, even if your bike matched the description exactly the download would not be perfect for your bike as no two bikes are exactly the same even running the same parts.
    Having said that it may well be just fine, thing is you don't know that unless it has been checked, best way to check it is to get it tuned, then you know its right, just my 2 cents mate.
  • Hudson76
    Hudson76
    Nothing better than a proper dyno tune. They seem expensive but are worth every cent and much cheaper than an engine rebuild due to running lean (and hot).
  • AlHD48
    AlHD48
    thanks for the advice guys , the bike is running very well , not sure what tune/download has been done in the past as i just purchased the bike not long ago.
    Sounds like the best thing to do is get a dyno tune.
    Any recommendations on who is the best in Melbourne ?
  • terroristone
    terroristone
    Dyno tuning is the best thing you can do, once its done you'll think it was a pos beforehand.
    Regards Andrew.
  • AlHD48
    AlHD48
    Thanks for the advice guys.
    Andrew when you got your bike tuned did you find that when you put on your quiet baffles it restricted the power alot ?
    do you think it might be best to get rid of the short shots and put the stock pipes on with S & S mufflers? not sure if the change will result in much better preformance , I do like the black out look
  • mickle
    mickle
    And who Tuned your bike Andrew.
  • terroristone
    terroristone
    Read below guys! i actually have the worlds fastest 883, all with shortshots and quiet baffles fitted! Its all about the tuning.
    Regards Andrew - AA Custom Cycles.
  • AlHD48
    AlHD48
    Andrew did you do the tuning ? is there someone you can recommend ?
  • prav03
    prav03
    HI,
    I have same SE heavy breather and V & H shot shots. Like to know how and where I can check my tunings? I bought it from Peter Stevens early this month and they said its been tuned, but don't know what they tuned?
  • AlHD48
    AlHD48
    Prav , I bet its just a canned map which is pretty much 100% of the time just the stage 1 download .
  • prav03
    prav03
    Thanks for the reply.
    I like to know the mapping they have done. Is there a way I can track that?
  • locks
    locks
    The last cal flashed into your bike is stored in your vci, pull it and compare it to the canned cal of the same name, you will see if it has been modified, I doubt it though.
