Online: HD17
Loom tidy?
  • dkNigs
    dkNigs
    Just test fitted my lowered tank and didn't realise how much the plastic loom cover sticks out on the right side of the bike, left is fine, nice and tucked under the frame. Is there such a thing as a compact loom cover? Otherwise best way to tidy it all up? Wasn't really planning on messing with the wiring, definitely not running it through the frame.
  • brash
    brash
    http://www.hdforums.com/forum/sportster-models/615890-wire-tuck-under-tank-with-no-tank-lift-my-take.html
    http://xlforum.net/vbportal/forums/showthread.php?t=323347
  • dkNigs
    dkNigs
    Yea I'm feeling I'll just have to zip wire everything to the frame. New bike under warranty, so not cutting any wires.
  • brash
    brash
    use some good self fusing tape mate, zip ties and vibrations eventually will wear through the wiring.
