Battery Light problem.
  • Pearcie
    Pearcie
    Hi there.
    Hopfully some can help me out with this or show me the right path.
    I have an 07 Night Train and recently have been experiencing (while riding) the engine/code light coming on as well as the battery warning light.
    The battery is about a year old. I have taken it into a battery shop and had it tested. 3 differnt tests done on it... all fine in perfect condition.
    After a Full overnight charge
    I tested the voltage.
    Bike cold.... 12.35
    Bike idling.... 13.85
    Under load..... blinker on / Brake light on / high beam on.......  about 12.60
    this is where it gets funny......
    After load test ........ and back to idling.......17.25 - 18.50 V ????????
    Is this Normal ????
    What is my next step?
    Bike starts and runs fine every time.
    Hope someone can help,
    Thanks guys
  • PeterGordon
    PeterGordon
    Hmmm, you do have a problem.  I suggest you see if there are any fault codes logged in the CPU.
    I'm thinking it may be a voltage regulator problem.  The voltage should be between 14.3 & 14.7v @ 3600rpm @ 24 degrees C.
    Any voltage above this is certainly going to fry your battery really quick!
    Good Luck
    Pete
    Yep reg but do a intro or you will get a lashing
  • rider
    rider
    Not normal, regulator is faulty,
    if it'e charging 17.25 to 18.5 volts at idle, what.s it letting through at higher revs ?
