Online: Stuart
Yet Another 883 / 1200 Question
  • fmacdonald
    fmacdonald
    G'day
    I am looking to buy the 883/1200 HD Stage 2 kit  - 29836-10 (comes with the Head/Pistons, Cams, clutch spring and SERT) for about $1600 in Australia. I was quoted about $1600 to install in Sydney.
    At present I don't have the courage to installed it all myself or the money to get HD to install it so I was consider buying this kit and an aftermarket air cleaner, do the stage 1 myself for the moment and over time do the rest myself.
    Seems that most people are against the SERT but if I go for a 1250kit and PowerVision I will be over the $2k mark.
    FA
    What do you want to know?
    Should you go the SERT or the Powervision, up to you.
    If you feel comfortable installing parts your self, do it.
    If not, save some more money and get it done properly. ps. obtain quotes for the work, ask around for prices.
    Another option instead of the SERT or Powervision is the TAB Auto tuner, they work pretty good too.
  • fmacdonald
    fmacdonald
    Sorry, was a bit vague :)
    I was interested in whether I was wasting my money getting the SERT or if it does an "ok" job as I can't see myself paying for a Dynotune for a while.
  • adadrian
    adadrian
    So the stage 2 kit is just the conversion ? Making the 883 a 1200?
  • terroristone
    terroristone
    Stay with the sert absolutely nothing wrong with it at all. I have been able to get them to work fine on big cammed bikes and even boosted bike. HD (screamin eagle) have a much larger R&D budget than any other aftermarket branded tuner. There are only a very few reasons why i'd not use the SERT and i have not built or seen a bike that needed to use anything else. Most would say to use something else as they dont understand how to use the SERT or get the most out of it. Autotune is a feature i will not use but wont get into here as it can be a long argument.
    Regards Andrew
  • fmacdonald
    fmacdonald
    Cheers Andrew, pity you are not in Sydney but I think I now have a plan of attack. While the kit from HD may not be quite as good as the 1250 kits there is something about buying OEM stuff.
  • fmacdonald
    fmacdonald
    HD have two 883 / 1200 kits both about $1600,
    1. Street legal 883 to 1200 that includes 1200 heads, SE air cleaner etc but standards cams and no SERT or
    2. "Race use only" uses the 883 heads but includes performance cams and SERT but no air cleaner
  • adadrian
    adadrian
    I got quoted over 3 grand for the upgrade to 1200 by The stealerahip
    I said forget it, I'll take the stage 1
  • Damo14
    Damo14
    Mate have you checked out DK Custom NRHS 1250 kit for the sporty, http://www.dkcustomproducts.com/NRHS-Sportster-883-to-1250-Upgrade-Conversion-Kit-DK-NRHS-1250.htm
    its not that difficult to swap out just get a manual and remember to be patient and take your time
  • terroristone
    terroristone
    I prefer to use the Hammer kits. So much better than the rest, good service and quality parts. The conversion with my extras usually costs about $2200 depending on the $ exchange.
    Andrew
  • brash
    brash
    how many rwhp you getting out of the 1250's Andrew?
    I just did a set of Hammer Jackhammer 570 cams and so far so good on base tune, got a fair bit to tidy up when I can get back on a dyno. I'd be happy with 83-85rwhp at 1200cc. Can't justify cost of heads yet.
  • terroristone
    terroristone
    I get with just the barrels and pistons (everything else 883) 85hp and 90T, which makes them quite quieck if you can ride and use all the power. If you looking for more well then the $'s go up in a big way.
    Regards Andrew.
  • fmacdonald
    fmacdonald
    Andrew, is that with the 1200 or 1250 ?
  • terroristone
    terroristone
