Online: Humbug, HD17, John.R, baldy1450, Wanderer57
Vance & Hines Quiet Baffles
  • brettm357
    brettm357
    Hello, Anyone here drilled the end cap on there Vance & Hines Quiet Baffles for a better sound
  • Drac
    Drac
    I tried the quiet baffles in my big shots and lost top end power but gained a lot of low down torque.
    I then removed the end caps by grinding the weld and welding stainless crimsafe type mesh over the end which gave me good low end and some more mid range power.
    I have now removed the mesh which gives a bit more mid range power and a deeper sound without sounding too muffled.
    Still down on power compaired to the standard baffles.
    I should mention the bike is a 2012 fatboy with s&s 570 cams which was producing over 100 hp and now I think it would be under 100 hp.
    Dont know if I will leave them in.
  • brettm357
    brettm357
    read on the net if you drill hole in the end it give good midde ground between standard and the quiets - quiets seem to muffled
