Online: HD17, John.R, baldy1450, Wanderer57
Tracker bars on a Dyna
  • Difficultmonkey
    Difficultmonkey
    Have been looking at replacing the stock mini-apes on my Street Bob with something lower, possible tracker style like this:
    https://s-media-cache-ak0.pinimg.com/736x/f7/1b/74/f71b74c25f0ddf8400415253d7a304e4.jpg
    or this
    https://s-media-cache-ak0.pinimg.com/736x/f0/34/50/f0345014c354568e3ff31ae1d42b0d09.jpg
    Or this
    http://smg.photobucket.com/user/Bulldogxj/media/cccce0f1.png.html
    or this
    http://makergo.com/shutup/?cat=49
    However! I can't find bars that look anything like that aside from the Chubby 1 bars which are about $300 once you get them delivered to Australia.
    Has anyone done something similar and have a suggestion?
    Thanks!
  • Ranga
    Ranga
    Have you thought about Bad Boy bars. They are not a lot different from the last one you have listed. Mine were @ $100 from HD Development.
    Dyna's we race em with just 883 bars 1"to 1 1/2" up & short ,  good handling & great for going thru traffic, i cut the end's  down a bit just enough the fit da switch blocks on,   even better ,we  use stock sportster or v-rod grip's work great small radius
  • nhb006
    nhb006
    Plenty of Nightrod pull off's around. I had XR1200 pull off's on mine.
