Online: Stuart
Tools require to work on your HD.
  • vladt
    vladt
    18 years ago
    Hi All,
    I just bought my first HD (Street Bob) and would like to do all the work on it myself.
    Could anyone please list some of the more common tools you need to work on your HD.
    Vlad
  • Paul.C
    Paul.C
    18 years ago
    You will need,
    A set of star shaped allen key's
    Imperial set of spanners and sockets.
    That'l get most things on and of your bike.
  • cattleprod
    cattleprod
    18 years ago
    The Star shaped keys are called Torx.
    Invest in good quality SAE open and ring spanner set ie: 7/16" to 1 1/4" (King chrome make a set with metric as well)
    Most common sizes are 1/2", 9/16", 5/8"
    Good set of SAE Sockets including a spark plug socket
    Good set of SAE Allen keys
    Phillips head and straight blade screw drivers (Don't scimp on shit ones)
    A bike lift makes some jobs easier (Well more comfy anyway)
    Assorted bits n shits, you'll work it out.
  • vladt
    vladt
    18 years ago
    Thanks heaps guys. Will have to do some tool shopping this saturday.
    Do you use torque wrench much when working on your HD?
  • shadowhand
    shadowhand
    18 years ago
    A torque wrench is needed if you want to do regular servicing.
     Correct torque maintains fastner integrity.
  • mattro11
    mattro11
    18 years ago
    Your also gonna need a 10mm 12 point spanner / socket to work on the brakes.............................
  • Deadly
    Deadly
    18 years ago
    Yep, 3/8 drive for bikes, 1/2 for cars, 1' for trucks and 1 1/2 for large earthmoving stuff.
    Remember all torque listings are for clean and dry (no oil) parts unless a lube or tread locker is listed with the touque value. A dry listing of 25ft.lb with an oiled bolt is equal to 32 - 35ft.lb = stripped tread!!!!!!!
  • cattleprod
    cattleprod
    18 years ago
    As me old dad used to say "After tight comes loose".
  • Noodle
    Noodle
     ... for me, I've invested in tools all my life.. I generally get quality.. but, as far as the Torque Wrench is concerned.. It would have to indeed be THE ONE... mostly neglected, or if we have one, it's usually inferior .. Mine is..
    I'm currently waiting for a Warren & Brown deflecting Beam Torque wrench.. my other one is one of the clicker type.. which I will toss..
    This one being .. Part Number - 321500
    Capacity - 4-90 ft.lbs / 5-120Nm
    Drive Size - 3/8"
    Length - 37cm
    Packed weight - 1.3kg
    I expect this one to cover pretty much all of my smaller range torqueing requirements.. ??? But it is what I particularly need for now..
    ... after reading, and searching many hours over the weekend, I came to the conclusion that Warren & Brown being an Australian made product .. has got to 'out-class' just about anything out there.. after reading the US HD forums.. they don't have, such a thing as an acoustic feed- back deflecting beam (makes a click sound).... and there saying this is the biggest issue with using one.. W&B have been around for over 80 years.. and must have the patent on there design... I know if you do the amount of reading .. I've just done, you'll come to the same conclusion...
    .... I'd encourage us, to promote what may be the best of the best... of what we have, as we are indeed supporting the US .. our turn now, to let them know we have something to offer also... I've contacted W&B, and indicated to them, that I will indeed, pass on this information... some of them already are 'in the know', as I read a 'Honda Accord' Forum.. in the US.. they were speaking of this Torque wrench.. I felt a little pride...
    I will respond to our US counterparts .. and promote an Australian made product..
    LIFETIME WARRANTY.. and certified calibration. Yes, and it can be recalibrated...
  • Noodle
    Noodle
     http://home.jtan.com/~joe/KIAT/kiat_1.htm
    I was a book worm over the weekend... Locktight or Loctite® Tight® is indeed a part of good 'house keeping' .. but you will find the bolts are actually Springs in there own right.. and under 'Pre-load'
    .. for information to all, and sharing..
  • V2Evo96
    V2Evo96
    I find a set each of allen and torx head 3/8" drive sockets to be very useful. They come clipped on a strip that you can mount somewhere if ya want to.
  • too old
    too old
    Don't forget a 1/4 ball head allan key stub for your starter motor. I just bought the best allen key I could then cut 1 inch of the end to get the left bolt of the starter to work on the primary
    I bought a paper repair/maintanence manual but also got a download and a disc for around $13.00 at www.repairmanualsoncd.com
    great correspondance and quick. I had asked in the" wanted to buy" forum and help came from every where
  • FXCowboy
    FXCowboy
    Get tools with a lifetime warranty. The cheap shit won't hold up, and if you damage one with a no-questions asked warranty they'll change it over for you. I generally try to buy all my auto-tools from a single supplier, makes it easier to swap things over if needed.
    SP is good stuff - personally I don't like Kinchrome. Had a cheap torx bit that twisted getting my derby cover off, and that shouldn't be on tight. Sidchrome isn't what they used to be but there are some good deals out there.
    Check out Jims catalogue in the US. They have a heap of harley specific tools you might need, depending on what you're planning.
    The Warren and Brown micrometer torque wrenches are some of the only ones that will measure torque in both directions. This is a consideration if you're working on the compensating and clutch sprockets since they are high foot pound, one is left and the other right handed threads. Most of the other threads will be normal so any torque wrench will do. The W&B that measured in both directions was not cheap, but a 40-200ft/lbs wrench will do most of the bolts you don't wont coming off at speed and if does both threads that's a bonus.
    The deflecting beams wrenches are good - but will only measure torque in one direction (clockwise) unless they have a socket adapter that allows you to flip them over and use them in the other direction.
  • Topgunint
    Topgunint
    6 years ago
    One of the biggest problems on most bikes is checking the tyre pressure when not in your garage.
    This is the best tool around for checking and pumping up your tyres when your out on the road.
    Have a look on the website
    topgunrider.com
  • steelo
    steelo
    6 years ago
    Could be worth a look. Especially how it fits onto the rear wheel for tourers
    6 years ago
    Does seem like a decent bit of gear
  • Ken in Cairns
    Ken in Cairns
    6 years ago
    If you buy a torque wrench, calibrate it, not hard to do, u tube has some good vids on it.
    I have a W B inch pound unit and a spring type foot pound one that I calibrated and that does me.
    Some Crow foot spanners are handy, esspessially for in the rocker boxes.
  • berserker
    berserker
    6 years ago
    If anyone's replacing a clutch cable you will also need a decent set of circlip pliers. Theres a rather large circlip in the trans cover that needs to be removed to reinstall the cable.
    The other important tools are cold beers and a stubby holder. They assist with the enjoyment of maintenance
  • Ken in Cairns
    Ken in Cairns
    6 years ago
    The circlip for the clutch lever pin is quite small so you need a small out side and a large inside one.
  • berserker
    berserker
    6 years ago
    Your right ken. I filed down a cheap set of circlip pliers for that clutch lever pin circlip as it's so small and the holes in it are tiny. But there's a large circlip holding the other end of the cable. The one that goes into trans cover with the ball and ramp assembly. At least on the late model twin cam dynas annway
