Weeping Rocker Cover Bolt--2006 Dyna
  • daccadan
    daccadan
    Hi All------for no reason (?) the back RHS bolt securing the rocker cover on my 06 Dyna has begun to weep oil.
    I have tightened it and it still weeps oil---dam annoying---bike has only 35K on odometer.
    Does it need new washers--new bolt?   Any advice would be good.
    Dan
  • crewman
    crewman
     I had the same problem wth mine and I took out the bolt -give it a good clean then put it back in with a bit of sealer . So far so good. Even though I can't ride much now and selling off my bits n one of my bikes
